05-16-2022 04:34 PM - last edited on 05-16-2022 04:38 PM by computergeek541
My billing cycle is the 3rd of the month does that mean my data and minutes replenish on the 3rd of the month as well?
05-25-2022 10:44 AM
Top of the overview page in the light blue pay before date. Or dial 611 and hear the renewal date. Or 1-855-4pu-blic and the same as 611.
05-25-2022 10:30 AM
Is there somewhere I can check to see when it is scheduled to reset? It would be so much easier if it were visible on my profile
05-16-2022 04:57 PM
It will always be moving slightly, but regardless, yes...whatever your renewal date will be when the clock resets (data, minutes if on the 15 plan, etc etc)
05-16-2022 04:38 PM
@Dipasquale wrote:My billing cycle is the 3rd of the month does that mean my data and minutes replenish on the 3rd of the month as well?
Your billing/renewal date won't be on the same day each month as all of Public Mobile's current plans are 30-days long, but yes, your plan data and minutes included with the plan reset at the same time.
05-16-2022 04:37 PM
HI @Dipasquale Yes correct
But make sure you remember that PM has a 30 days cycle and NOT monthly. So, while it is the 3rd of this month , Let say May 3rd, the next one will be Jun 2nd, then July 1st, then July 31st
