12-04-2021 04:17 PM - edited 01-04-2022 04:56 AM
If you are planning to go USA after February 2022, you probably won’t be able to make or receive calls. AT&T will decommission 3G.
To make or receive VoLTE calls, Public Mobile need to enable VoLTE.
When you make calls with Public Mobile SIM, your phone fall back to 3G to make the call. If 3G is not available call don't work.
I can confirm you can’t make or receive call where 3G is not available in Canada.
Internet is working but not calls.
I recently went to Réserve faunique La Vérendrye, QC. Calls on Bell and Videotron were working with VoLTE but not Public Mobile.
08-22-2022 02:22 PM - edited 08-22-2022 02:39 PM
I would never change the plan I have.
08-22-2022 02:21 PM
That's the answer:
Addressing your concern about a reimbursement, we are sorry that service might not be available. We are working really hard to get Voice over LTE enabled for our clients, but there is still no update about it.
I want to set up the right expectations about your request, and extra features offered might be subject to changes like this specific roaming feature. As well, service for Canadian usage is still being offered and used every day! Therefore, service is still being provided.
If roaming might not work, and you would like to pay less, as previously mentioned, we are offering a $50 plan for 10 gb at 3g speed unlimited talk Can wide & unlimited Int tex.
We understand your refund request, and we wish it was available, however, prepaid services are non refundable, and roaming service on Alaska might not work properly until we get an update or feature that might allow our clients to connect properly. Stay tuned.
08-22-2022 02:00 PM
@jack4614 wrote:I did, dust2dust.
They offered to change my plan to a cheaper one. No reimbursement. (no comments for now)
HI@jack4614 , don't let it stop there, push them to have a senior support to review your ticket. Ask them if VoLTE coming. If you change plan now, if they have VoLTE for roaming next month, you won't be able to get back into this plan
08-22-2022 01:58 PM
@jack4614- lol Of course they did. Please don't. This has to get figured out eventually.
08-22-2022 01:56 PM
I did, dust2dust.
08-22-2022 01:52 PM
@jack4614- Remember to try asking about roaming contracts with AT&T. State that the help pages say AT&T and that Alaska is a state. You should be able to do text and data. Don't take the first flip lazy answer. Try to get it raised up to someone who would actually know. The first line support people are just that.
08-22-2022 01:48 PM
Alaska is still advertised as the 49th state :). Should still belong to the US..........
Anyhow, thank you guys for all your support, even if we don't find a solution.
08-22-2022 01:41 PM
@jack4614- I still wonder about AT&T roaming agreements but this is from the help pages.
We’ve partnered with AT&T and T-Mobile to provide you with fantastic coverage. Your U.S. coverage will include all 50 states, plus Puerto Rico and the U.S. Virgin Islands.
AT&T and 50 states. Last time I checked, Alaska was one of those states. Certainly not talk but text and data should be fine.
08-22-2022 01:33 PM
Thanks @dust2dust I missed that.
Not sure if CS agent can do anything for a one time compensation.
Just hope VoLTE will come soon. (And not sure why there are so many issues with Alaska. OP sees it but cannot connect to it..)
08-22-2022 01:32 PM
@hTideGnow- Please read his replies. He's on the old $60 plan. Not add-ons.
08-22-2022 01:27 PM - edited 08-22-2022 01:27 PM
@jack4614 wrote:I am in Seward today and later back in Anchorage. I see AT&T. If I try to connect manually, the phone tells me the network is currently unavailable. A friend of mine with a different carrier uses AT&T with no issues.
HI @jack4614
Pretty sure you won't have luck in Anchorage as well, some already tried without success there
Since it didn't work, you can open ticket with CS agent and as them to cancel the add-on for a refund. They will do it without much trouble.
open a ticket with PM CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
08-22-2022 01:19 PM
In Canada, it works fine everywhere, yes.
08-22-2022 01:18 PM
@jack4614- No. VoLTE is not supported by PM. The phone works fine for you in Canada right? There's a rumour that Public might be implementing VoLTE in the Fall. But truly just a rumour. Then they would need to contract with roaming partners to allow those kinds of calls.
08-22-2022 01:17 PM
My settings at the moment
08-22-2022 01:12 PM
Yes, It is set on LTE.
VoLTE would work, I heard, but Pixel6 is not supported by PM.
08-22-2022 01:10 PM
@jack4614- Well they don't have control over what roaming partners do. Maybe you could get some clarification on whether AT&T is still a roaming partner and report that back to us. Is your phone set to LTE/4G?
08-22-2022 01:07 PM
The main issue is that PM doesn't care.
"It doesn't work. Sorry."
08-22-2022 01:06 PM
08-22-2022 01:04 PM
@jack4614- Yes that would be frustrating paying for that plan all this time through a pandemic only to coincidentally find that the providers have mostly turned off 3G service now that you can use it.
I'm surprised you have no AT&T. I had understood that at least text and data would still work with them. But maybe the contracts were ripped up when they turned off their 3G.
08-22-2022 01:03 PM
Hi @jack4614 Which city you are in now? Many reported that they don't see AT&T network there
if you see it, try manual connect as well as try Automatic.
08-22-2022 01:01 PM
AT&T is here, everywhere. But I can't connect.
08-22-2022 01:00 PM
HI @jack4614 If it is Alaska, there is no T-Mobile or AT&T there now. In this case, you need to use local mobile data
08-22-2022 12:58 PM
I can't. There is no T-Mobile in Alaska. AT&T would be available, but the phone doesn't let me connect. "AT&T is unavailable." Full reception.
08-22-2022 12:56 PM
HI@jack4614 you can still use US roaming
For voice, T-Mobile still has its 2G network which PM roaming can use . So, you can buy US roaming, and then select T-Mobile as the network, your phone will use it's 2G for voice and it's LTE for data
of course, you can also just buy data roaming and use VoIP all like Fongo or TextNow to make voice calls. If you are using only Data roaming, you can choose either AT&T or T-Mobile when you are there
08-22-2022 12:51 PM
It is August 2022; the US turned off 3G. I have a plan with US ROAMING included and a Pixel 6 pro. No VoLTE is available. I am not able to use public mobile anymore. No solution was offered. Only sorry. Means: That's it for our relationship. Unfortunately.
12-06-2021 09:28 PM
VoLTE is a separate bandwidth share dedicated for talk. It can be managed separately from primary data provision. There's really no reason a provider (like Public Mobile) can't support VoLTE on a VoLTE-capable network while also supported throttled LTE-based data - aside from the arbitrary business decision to not do so. They might cite technical complications, but these are really just artificial obstructions which could be implemented differently if they really decided to make it happen.
12-06-2021 08:43 PM
The perfect reward to help you share the spirit of the season.
At Public Mobile, we’re all about giving. So we want to give you another reason to refer a friend to us. Between December 1, 2021, and December 31, 2021, refer a friend and we’ll take $5 off your payment every 30 days for six months as long as they stay with us. See details below.
this should tell you their plan for the future. I think we get volte in April after the T-Mobile 3g shutdown. pm needs to increase the throttle limit though. I can already tell volte won't be a success without it. the lte connection with the 3mb throttle is too inconsistent... it needs to have a buffer and 3mb can't provide it.
12-05-2021 04:18 AM - edited 12-05-2021 04:32 AM
PM has made tons of improvements in the past couple years. they've been leading the pack with newer plans and better promos. I don't really see them shutting down.
T-Mobile and at&t both have volte on prepaid... it's going to depend on whenever Telus decides to disable the filter.
12-05-2021 01:48 AM
Well, I certainly hope they don't vanish, because I can actually afford to keep my line active thanks to this company.
12-05-2021 12:52 AM
@Korth wrote:
@CountyDownIeUk wrote:For some reason I have never liked Koodo....just because of that blue annoying mascot that used to advertise on TV!! lol.
He doesn't look blue to me. He looks Italian.
Wasn't totally blue ... but annoying.
