04-25-2022 09:18 PM - last edited on 04-25-2022 10:50 PM by computergeek541
I had $5 funds added to my account when I purchased the sim but I can't seem to find it in my account.
edited by computergeek541: miscategorized (not reward related)
04-26-2022 03:09 AM
@dust2dust Thank you. I opened a ticket for the complaint, and an agent was able to resolve it for me.
04-26-2022 03:07 AM
Hello @softech, I opened a ticket and it has been resolved. Thank you
04-25-2022 10:50 PM
In 611 or account? How long ago? You can try to enter it twice per hour. At least until the support people figure it out for you.
Can you also look back in your payment history for all transactions and maybe the $5 was there. Did you buy any add-ons? Are you sure the renewal hasn't happened yet?
If only you had included more in the image.
04-25-2022 10:15 PM
@dust2dust Twice
04-25-2022 10:03 PM
So you tried entering that voucher in the account or dialing 611? And it came back as invalid? How many times had you tried?
04-25-2022 09:49 PM
@softech I will open a ticket with PM support now, thank you.
04-25-2022 09:47 PM
@SusieOkeowo you sure LD didn't charge you $5 for the SIM card itself? Open a ticket with PM Support first and provide them all the information and see what PM says. Worst case, you can go back LD for their false "advertisement"
let us know how it turns out
04-25-2022 09:47 PM
@dust2dust Yes I do. There's a 12-digit voucher code but it's invalid.
04-25-2022 09:45 PM
@softech Screenshot removed, thank you. The activation is over 72 hours
04-25-2022 09:42 PM
Do you still have all the paperwork from the purchase? Does any receipt have a set of 12 digits called PIN or something on it?
04-25-2022 09:41 PM - edited 04-25-2022 09:42 PM
@SusieOkeowo Please remove the screenshot , it has your account number. Remove it for your own protection.
How long you have activated? usually PM support will add it within 72 hours. if it has not been 72 hours, yet, please wait
When is is over 72 hours and you still not see that, please open a ticket with PM support:
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
04-25-2022 09:39 PM - edited 04-25-2022 09:43 PM
04-25-2022 09:38 PM
@JL9I haven't made a renewal yet, this will be my first.
04-25-2022 09:36 PM
@softech, thanks for the response. I bought my first plan of $15 for $20 at a London drugs store and I was told that the $5 balance will be funds added to my account. But unfortunately, my available balance is $0.00
04-25-2022 09:30 PM
The $5 credit will be on the top right corner of your account page under Balance.
04-25-2022 09:29 PM
The 5 should then show in your available funds and may have been used towards a renewal already (so your plan would have been 5 cheaper) if neither of these things happened you would have to either go to the store/kiosk that promised you this or speak to a CSA to track this down.
04-25-2022 09:26 PM
@SusieOkeowo Where did you buy the SIM and what was said that the $5 will be applied ?
If PM was the one applying you the $5 credit, it will appear as Available Fund on My Account and can be used for your next plan renewal.
did you open a ticket with PM and they promised to reimbursed you the amount?
