09-20-2022 05:38 PM
Hi,
I had my daughters phone set up and automatic payments coming out for about a year but a couple of days ago, she no longer shows a network, and phone just says invalid sim card, or no sim card.
If I call her number it goes straight to voicemail. If I try to log into the PM website using my saved username/password, it says invalid username/password. Trying to restore it says a message is sent, please use 6 digit code, but no email in any of folders, junk, promotions, etc.
Thanks
09-20-2022 07:16 PM
@ballylama - what does it say when you dial 611 from her phone with the sim card inside?
OR dial # 1-855-478-2542 to check the status of her account.
If Active, then try:
If account is Suspended, autopay fail may have failed. Make a manual payment to reactivate the account.
09-20-2022 05:43 PM
Hi @ballylama and for your login problem, since it is a problem that you don't get the 2FA code, using Incognito mode won't help. Please open ticket with CS Agent :
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
09-20-2022 05:40 PM
Hi @ballylama please try to reboot your phone first
Still not work, then put your daughter sim card in your phone and see if it works. This can tell if it is a device problem
09-20-2022 05:39 PM
trying use different browser,open incognito mode,clear cache,cookie, try Login
or open ticket with PM support and ask them to do it out for you.
At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS Agent at:
