International roaming charge
Kasif
How much roaming charge for pakistan
2 REPLIES 2
hi @Kasif  sorry, PM only has roaming services for US and Mexico and no wheere else
To have data for your trip, you will need to buy local data sim or travel esim.
For voice, download VoIP app ahead of the trip, setup and get another 10 digits phone number, you can then make and receive calls using the app.
And with 2FA, you won't be able to receive the codes sent to your PM number or sent to the VoIP number, so, you will have to arrange to change it to email or use Authenticator app ahead of the trip
@Kasif  Sorry public mobile only has roaming in the U.S. and MEX no roaming in Pakistan . Your best to get travel sim for your trip or local pre paid sim in Pakistan instead
