International Roaming
KD3625
Hello All,
I was wondering if there is an International roaming option available to a public mobile cellular
(To simply: for example, I’m currently in Canada and going to Asia with the same Public mobile Sim card, and I am looking to use public mobile services in Asia, is there any way? )
Answer will be much appreciated
HALIMACS
@KD3625
No PM roaming service in Asia.
Additionally, depending on your device make/build, it may not be usable in Asia even if you purchase a local SIM plan there.   Before buying a SIM plan, make sure your device is usable with the frequency of the mobile provider there.
Meow
No, there is no international roaming with PM. Your option is to get local SIM or voip app like TextNow.
Only 'international' service is provided in US through appropriate add-on.
@KD3625   No, PM only offer roaming for USA and no where else
you will have to check with local data option with VoIP app for voice
