07-31-2022 03:44 PM
All incoming calls forwarded to voice mail. Prior to switching sims yesterday all was fine....call forward is showing disabled but here we are!!
07-31-2022 04:55 PM
that is nice you reply yes then do rebooting device.
07-31-2022 04:54 PM
@Bill_par - you may also want to confirm/check below if services are still not working:
*try your SIM card into another compatible phone...this could rule out a device issue/setting.
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Otherwise, maybe submit a ticket to CSA from the link I added in my first post.
07-31-2022 04:50 PM
My reply to message...
07-31-2022 04:38 PM
HI @Bill_par did you received a sms from your old carrier? did you reply YES? You might have missed that steps and the port was stuck
I will send you a message to your Community inbox. Please check and call them to talk to live person. They will re-trigger that process
07-31-2022 04:34 PM
07-31-2022 04:17 PM
@Bill_par - if you said yes to the SMS approval port, have you restarted the phone yet with the pm card inside? Maybe do a reset of network settings as well...not a bad idea to do this after a new provider activation.
If you have activated a new account and transferred over from another provider, note that incoming calls are usually the last to port over.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If still issues, submit a ticket with Public Mobile representatives (CSA) for help; click this link: to request the transfer of your number over to Public Mobile.
Or, for you can try calling the Telus porting phone number, which we are not supposed to post here. So, check your private messages I will send it to you there.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
07-31-2022 04:10 PM
Yes X's 4....we moved all our mobile phones from ma...Bell. We are all having the same issue... outgoing is fine...incoming direct or forwarded to voice
07-31-2022 03:49 PM
when you port in here do gettign from old provider SMS about port out and you reply yes.
