I want to yodate my address
Kamille
Hi, can someone help to update my billing address please.
Kamille
Hey. Thank you. I got it changed on my 5th try!
Kamille
Hello. Thank you for your response. It’s really helpful. I was able to edit the address but I can’t change the province and postal code though. It says invalid address if I will enter the new province and postal code.
Dunkman
@Kamille
If using the website, I had a hard time finding the edit address.
Go to profile section.  Then click on edit Account name.  Then the option to change the address is in that section.
With the App, Go to Account section.  Then Manage profile.
slusagm
PM does not care billing address
If you really need to update it, use PM app
 If you need to update card, just make sure postal code is correct
