10-04-2025 02:05 PM
I want to remove old and expired credit cards from my account. THIS SHOULD BE A SIMPLE PROCESS...WITH EVERY OTHER COMANY IT IS!! I have tried to submit a ticket for customer service. But it will not submit. I am frustrated and plan to cancel service ASAP, unless I get some immediate assistance.
10-04-2025 03:16 PM
Hi @ DannyDee,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
10-04-2025 02:09 PM - edited 10-04-2025 02:10 PM
Yes, it is very simple, not hard at all. You just need to ask PM to help to remove it
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
10-04-2025 02:08 PM
Go to payment then update payment and change your information for your credit card
