08-01-2016 05:37 PM - edited 01-04-2022 02:55 PM
I used publicmobile two month ago.I am using Fido now, I want to back to publicmobile.How can I use back my old ID? I find my old ID is locked.
08-01-2016 06:24 PM
dhanadhan is correct. Get a new sim, open a new account and port your number back from Fido.See Port In
Welcome back.
08-01-2016 05:41 PM - edited 08-01-2016 05:42 PM
Well if you ported out then i believe your account is gone. Try logging into self-serve...
Most likely you will have to do everything all over again.
