09-19-2022 01:10 PM
09-19-2022 06:18 PM
09-19-2022 01:15 PM
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
Unless you really forgot your password I would avoid changing it particularly multiple times. At the end you have no idea which password PM saved last as as valid.
09-19-2022 01:12 PM
hi if you are having that many issues you need to contact customer service agent to help reset your account login
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
09-19-2022 01:11 PM
@Loribuzzell it could be just a browser cache issue. Try to use Incognito mode to login with the latest password you changed.
If still fails, try to go through the whole password change on Incognito mode, or on a completely different browser
If none of these work, open ticket with PM Support:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
