09-18-2025 02:04 PM
I upgraded from the 80 to the 100 gb plan. It charged me for a full month but only gave me 20gb of data for the next month. Apparently I need you ask a moderator to reset my data usage. How do I do that?
09-18-2025 02:36 PM
Swiping the screen refreshed with correct data. Thanks.
09-18-2025 02:07 PM
first off...log in to your account on a laptop but use incognito mode to check your plan status. Alternative...dial 611 to hear current plan status.
09-18-2025 02:07 PM
it is just a browser or app cache issue. try login browser with Incognito plan and you should see the correct plan
09-18-2025 02:06 PM - edited 09-18-2025 02:07 PM
You need to reboot your phone by powering off your phone then back on.
You can login to your account on the PM app then swipe down on the screen to update the data.
