11-30-2023 12:17 PM
11-30-2023 01:00 PM
Tmobile
11-30-2023 12:43 PM
HI @Kampfoster (and @Bud52 )
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
With voice issue, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
11-30-2023 12:40 PM
11-30-2023 12:39 PM
Florida
11-30-2023 12:38 PM
I think text works and I m using wifi. How do I connect to a phone network?
11-30-2023 12:31 PM - edited 11-30-2023 12:31 PM
You must connect to either AT&T or t-Mobile. Has the phone been volte enabled by PM ? Which state are you in ? Is data and text working ?
