11-12-2022 08:25 PM
11-13-2022 10:33 PM
@phyllisschnick6 wrote:thanks computer geek . . . .. .i spoke to virgin two times and they claimed each time that they didn't have a "carrier lock" on. So I guess I'll call them again. . .. .good to know Bell is the parent . . .. thanks again. . .. .
You will need to keep contacting them until they unlock it for you. If there's no success, you're going to have to file a complaint against Virgin with CCTS.
11-13-2022 10:29 PM
11-13-2022 10:27 PM - edited 11-13-2022 10:28 PM
@phyllisschnick6 wrote:thanks for your reply
not it says "SIM locked to carrier"
the carrier says it's not locked
though i see the apple literature saying "it might take a couple days" . . . .wow. . . .. so i guess i'll wait
d
Virgin Mobile is giving you false information. Your phone is locked to Bell. The SIM not supported message confirms that. Watiing 2 days won't help because it sounds as if Virgin Mobile never submitted the request to Apple to have the phone unlocked. You will need to contact Virgin again and hopefully you get someone on the line who doesn't repeat the same false information.
11-13-2022 10:15 PM
bought in canada 2 years ago with virgin - now switching to Public (TELUS)
11-13-2022 09:30 PM
d
11-13-2022 04:41 PM - edited 11-13-2022 04:42 PM
In general about. Does yours say the same?
What country was the phone originally purchased in?
11-13-2022 11:49 AM - edited 11-13-2022 11:54 AM
Couldn't agree more 🙂
But that message means locked.
Adding - is this a new to you phone? Or have you accumulated a bunch of information on it? If new then try a factory reset.
And you did check the devicecheck.ca mentioned?
11-13-2022 11:46 AM
bill paid, not blacklisted
sim works fine in another phone
old carrier says it's not locked
apple says it's not locked
apple sucks
11-13-2022 11:45 AM
rebooted
checked sim again
checked old phone company
checked apple
sim works in another phone
apple sucks
11-13-2022 11:44 AM
"SIM Not Supported - The SIM you currently have installed in this IPhone is from a carrier that is not supported under the activation policy. . . .." etc etc. Previous phone company says it's not locked. . . .. Apple says it's not locked. That was 2 days ago - phone still doesn't work
11-12-2022 08:34 PM
@phyllisschnick6 is that a phone you just got it? Where you got the phone from? Can the phone read other sim card?
If you just bought the phone, maybe check if the phone is blacklisted
11-12-2022 08:32 PM
as @computergeek541 says....then reboot phone.
11-12-2022 08:27 PM
Is there a specific error message that your phone shows? There's a small chance that the SIM card might not tne aligned properly, so you haven't already, try taking it out and re-inserting.
