03-31-2023 10:33 AM
I'm not a member. My mother in law is. Her husband has passed away, she's been trying to figure out how to speak to someone and it seems to be impossible. It's actually quite annoying. I had to make up this account. Like how do I speak to someone.
03-31-2023 12:23 PM
Yes this can be very frustrating but necessary because of security. If account setup with auto payments then find out from what credit card or debit card the payments are withdrawn and put a block on them.
03-31-2023 11:04 AM
@Roach85 yes, you do. Please open ticket with PM Support by direct message as advised above
03-31-2023 11:00 AM - edited 03-31-2023 11:01 AM
Yes, either that or when the associated credit card attached to the account closes, which it should, the account will automatically terminate.
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
03-31-2023 10:58 AM
She can't login to his account. So I will have to make a ticket number for support?
03-31-2023 10:51 AM
I've sent the private msg. She doesn't know his pin or his account information so she can't get on anything.
03-31-2023 10:48 AM
If the credit card used was in his name and your MIL doesn't use it then when that card gets closed then this place can't be paid and it will go into suspension and eventually disappear.
Or dial 1-855-4pu-blic and enter his phone number which will give you the next renewal date. Then the MIL can log in to the credit card account and pause the card for the overnight of the renewal.
03-31-2023 10:47 AM
@Roach85 Sorry for the loss
If she can login to the My Account, then she can disable the Pre-Authorized payments from the Payment page.
If she cannot login , please open ticket with PM support here:
03-31-2023 10:46 AM - edited 03-31-2023 10:49 AM
The only way to cancel around here is to remove the payment Source from the account. That is just a matter of taking the check mark off the enable auto pay in the customer's self-serve portal.
Added:
If you'd rather deal with a customer support agent of public mobile, the only way is online through the ticketing process.
