12-19-2022
12:45 PM
12-19-2022
01:32 PM
computergeek541
12-19-2022 02:26 PM
@Itsmynumber wrote:And I am unable to sent text messages.
Best for you to start your own new thread in the Community Forum.
12-19-2022 02:10 PM
12-19-2022 01:18 PM
Can you provide more details?
12-19-2022 12:54 PM
@Pandith there has been many reports today about incoming call issue, but you have outgoing calls problem too?
do you see your phone connected to the network? did you try reboot your phone and did you try to reseat your sim card? do you have another phone to test the sim card?
And, login to My Account and confirm your account status
Please provide us more details as in what works and what not and what did you try
12-19-2022 12:53 PM
You should login into your account and make sure that your plan is ACTIVE and not suspended.
Auto pay failure happens sometimes without you knowing. Until you can't make calls etc....
12-19-2022 12:52 PM - edited 12-19-2022 12:53 PM
If you are on an unlimited plan try the following:
Reboot phone
Reset network settings
Reinstall sim card
Put a 1 in front of the number
Also try sim in another unlocked phone.
12-19-2022 12:48 PM
@Pandith...
do you have the $15 plan that only has 100 minutes of outgoing calls ? Log in to your account to check account status...
