06-03-2025
07:04 PM
06-04-2025
12:10 AM
computergeek541
I already have a PM account and cell plan, would I be able to get another cell plan from PM and port my landline number to the new plan and have 2 cell numbers on my phone? Currently my cell number is with an esim. I tried to port the number but got stuck on the address input not being accepted for some reason.
TIA for any help
06-03-2025 08:34 PM
Ok no worries, once the ported number is active then I come and submit a ticket to get the referral code applied?
Thank you!
06-03-2025 08:29 PM - edited 06-03-2025 08:32 PM
Remember I told you land line port take 3+ days?
It is normal what you see. For the next 3 days or even one weeks you landline will work , both in and out
Your new PM line can make calls and can text but not receive calls/text
Until the line is ported, you won't be able to get 2fa and hence cannot login My Account. So wait and ask PM for the referral code after line is fully ported
06-03-2025 08:24 PM
Hello
I seem to have an issue right now and it appears that my landline is still active even though it said that the number was ported to the new PM plan, the charge went through on the credit card and the esim was activated but when my landline number is called the landline still rings. Also when trying to access my new account it says that it has to send a 6 digit code to my new number to confirm it's me but no code is received on my cell because the new number isn't active yet so I'm not able to access my new account either.
06-03-2025 08:17 PM
That's good
Now, you need to open ticket with PM to ask them to add the referral code back
Using the new account, open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
06-03-2025 08:14 PM - edited 06-03-2025 08:14 PM
@das904 wrote:Ok it seems that I have it set up with the second line ported over (my Shaw landline) I wasn't able to use the referral code because I screwed that up so how would I be able to apply the referral code now?
You can reach out to a CS Agent creating a ticket to have them add your referral number AND get your $10 credit.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
06-03-2025 08:10 PM
06-03-2025 07:56 PM
As long as card not charged yet, then just close the app. uninstall, reboot and reinstall
Worst case, make the payment without referral code, you can ask PM to add it back after
06-03-2025 07:38 PM
@das904 wrote:Thanks,
I just tried setting up a new account with a different email address and selected a plan then put in my payment info and when I tried adding the referral code everything crashed and I don't believe anything was set up
Sometimes it happens. Do you see a charge on your credit card? If not, then try again. If it does it again, then double check the app is up to date. If it is, delete the app, reboot phone, download app again and try again.
06-03-2025 07:37 PM
Right now everything is screwed up and I can't seem to get back in to set up a new account, the screen went blank when I tried to add the referral code 😞
06-03-2025 07:37 PM
Make sure you use the app installed on your iPhone
If it crashed, uninstall and reinstall
06-03-2025 07:34 PM
Thanks,
06-03-2025 07:29 PM
@das904 wrote:I already have a PM account and cell plan, would I be able to get another cell plan from PM and port my landline number to the new plan and have 2 cell numbers on my phone? Currently my cell number is with an esim. I tried to port the number but got stuck on the address input not being accepted for some reason.
TIA for any help
Hello @das904
This is what I recommend. You need a secondary email account to start a second phone line here with PM. With that being said, start up a new plan, one that you want and get a temporary number. Then, make sure you can make and take calls, make sure you can text and receive texts. And finally, make sure you can use data. If all of these things work, THEN you can go into your account using THIS link, you can port over your Shaw home number. Just know, it can take up to 7 business days for the port to move over.
https://myaccount.publicmobile.ca/en/account/profile/transfer-phone-number
Finally, when you do sign up for a secondary account, make sure you use your original accounts referral code so you get $10 off your second month of service on your second line and you'll get 1 Point every month on your first phone line.
Hope this helps.
06-03-2025 07:19 PM - edited 06-03-2025 07:19 PM
Yes , iPhone 13 Pro has dual esim support
And yes, you cannot combine accounts here's do, you need to use a different email and create.a new account. Make sure your Shaw's account is active, request port after payment step. And porting from landline takes around 3 days or more
06-03-2025 07:17 PM
Hello
Thanks for the reply, I have an Iphone 13 Pro which I believe supports 2 esims, so I have to create a new account and get a new plan then port the Shaw number to the new PM account?
06-03-2025 07:11 PM
If you have a dual physical sim phone or your phone supports one physical and one esim , then yes (or if you have a newer phone that supports dual esim)
And you have to use another email to create another account, then request porting
In short, you are setting up a 2nd account for that, not on the same account
