05-08-2022 12:42 PM
Is the system having problems with renewals on Autopay? I had a note in my account to disregard the account suspended if I am Autopay. What is going on? Can't reach customer service through the auto bot - keeps telling me a log in error and yet here I am. What is going on? This is crazy.
05-12-2022 10:07 AM
Well, the phone suddenly started working last night - after several declines by the credit card company. This is truly bizzare and a bit concerning. I have asked Customer Service to look into this matter.
05-09-2022 07:05 PM
@Rogsmobile1 what is your current plan? if it is the $10 plan, please note that $10 plan is now $13. So, you will have to pay more to reactivate the service
05-09-2022 07:02 PM
Hello: I tried that. It did not work. I will see what customer service has to say. Thanks.
05-09-2022 05:54 PM
@Rogsmobile1 wrote:$4.00 is showing
@Rogsmobile1 Please make a manual payment in My Account using the option "Other (Enter the desired payment amount)". There, you need to enter your the amount $ (Plan amount - 4) ,
e,g you will enter $11 if your plan amount is $15.
Then click Submit
If the payment made successfully, click "Reactivate current plan" if the button is still there,
Then logoff from My Account and reboot your phone.
It should work that way
05-09-2022 05:36 PM
$4.00 is showing
05-09-2022 03:05 PM
@Rogsmobile1 how much showing in the Available Fund? $0? or some amount there?
05-09-2022 02:54 PM
Hello - tried that - no luck
05-09-2022 02:54 PM
Thanks for the suggestion.
05-08-2022 06:58 PM
Going forward, once you sort it out, you may want to manually add the required funds for the renewal a day or 2 before to avoid the autopay glitch, seems to be a good workaround, while not ideal you won't have to deal with this issue again
05-08-2022 03:27 PM
@Rogsmobile1 have you try a manual payment yet? Sometimes Autopay fails for no reason.
If you have not try yet, go to My Account, Payment tab, click one time payment and use the option "Other (enter thr desired payment amount)" and manually enter the plan amount and click submit. It it goes through successfully, then click the button Reactivate current plan if it is there. Then logoff from My Account and reboot the phone
05-08-2022 03:14 PM
Plan expires today - but no service today
05-08-2022 03:13 PM
Hello - not on 10 plan. I tried re-processing and it said card aurthorization failed. I will wait to hear from customer support and check with credit card to see what happened. Thanks.
05-08-2022 01:45 PM
@Rogsmobile1 any chance you are on the $10 plan? The plan is now $13 and PM had problem renewing some of the $10/$13 plan since the price hike on April 28
05-08-2022 01:43 PM
When is your plan due to renew @Rogsmobile1 ?
05-08-2022 12:50 PM - edited 05-08-2022 12:50 PM
If today is your renewal day and you use this, as long as you HAVE service, disregard it.
05-08-2022 12:45 PM - edited 05-08-2022 12:47 PM
Try your phone out. If you have no services and autopay failed which does happen, go to the Payment tab in self service and choose other from the drop down menu and enter the cost of your plan. Choose reactivate button if there is one, otherwise reboot after submitting.
Edit: clear browser cache/history and go incognito. Use chrome.
