10-28-2016 01:37 AM - edited 01-04-2022 03:46 PM
I only have ON plan. if I purchase the LD addon. Can I make a phone call while I am outside ON.
10-31-2016 05:18 PM
@zmh1175 wrote:Here is the right question.
@zmh1175 where?
10-31-2016 02:19 PM
10-28-2016 03:34 PM - edited 10-28-2016 03:35 PM
Also, it's not super clear by your post if you're asking if you can make a call *to* outside of ON, or if you can make a call *while* outside of ON. If the former, obviously yes. If the latter, it depends where outside of ON you are. Outside of Canada entirely, you cannot use your phone at all. Public Mobile doesn't have any roaming at all. Within Canada, you can make outgoing calls without using LD minutes to any number located in the province in which you are currently located. Any number outside of the province that you're currently in will cost you LD minutes. And *any* incoming call will result in using LD minutes as well.
If this isn't what you were asking, my apologies. But hopefully somebody else will find it useful if that's the case 🙂
and @Chaos_Scorpio - technically you'd be coming back to a brand new PM account, wouldn't you? So I'm not sure why you'd expect your addons to still be there 🙂
10-28-2016 08:23 AM
Addon do Expire ... if you cancel your service with PM and go to another carrier... they won't be there if you return because you later realized PM is way better than X company.
10-28-2016 07:39 AM
Yeah, that's correct. If you only have a provincial call, then you can use the add-on to call someone outside your province. Also, it doesn't expire. You can use the add-on until you use all the remaining minutes on it.
10-28-2016 06:50 AM
Here's the countries you can call with the International Add-On (including Canada and US):
Graphic is from this original post: http://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Calling-an-international-phone-number/m-...
10-28-2016 02:50 AM - edited 10-28-2016 02:50 AM
Yes, add-on do not expire untill you use all mins. International add-on includes 18 countries other than US & Canada.
10-28-2016 01:54 AM
Hi @zmh1175, Public Mobile has 2 long distance plans:
1) $8/month for 200 minutes Canada/USA
2) $15/month for 400 minutes International which should cover Canada/USA.
I believe these minutes also carryforward indefinitely until you use up all the minutes.
Where are you calling outside of Ontario? Canada/USA or International?
10-28-2016 01:42 AM
Yes, that is what long-distance add on is for 🙂
