01-13-2022
03:46 PM
01-13-2022
10:42 PM
Dunkman
Hello
I lost my old phone and cant find it on find my device app shows offline and doesnt show last location i put it in secure mode
Now i bought a new phone and new sim card but cant change sim on my account because it says need need code sent too my number but dont have access also the email i cant acess please help @ad
01-13-2022 03:51 PM
Send a private message explaining your situation to a CSA. After verifying your account you will be asked to answer 3 out of 4 additional verification questions about your account and service that are not readily available in your account. Have your payment card details handy. Once you satisfy the CSA"s inquiries they will perform the sim swap for you.
01-13-2022 03:47 PM - edited 01-13-2022 03:50 PM
You will need to report the old SIM as lost/stolen first in self serve. Then you can change your account to the new SIM there itself.
selfserve.publicmobile.ca
01-13-2022 03:48 PM
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
01-13-2022 03:51 PM - edited 01-13-2022 03:55 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
only them will change and reset for you,
Here’s How To Contact Customer Support Agent,
Good Luck.
01-13-2022 03:51 PM
01-13-2022 04:15 PM - edited 01-13-2022 04:15 PM
Odd that your email is used as your login to log into your account yet you don't have access to that email....When you contact support to verify that it is you. You probably should ask them to change your email as well to one you have access to....
