I can't receive calls
bragg2000
Hi I am unable to receive calls but I can make them. My phone goes right to voicemail when anyone calls me
9 REPLIES 9
bragg2000
I have tried all of this and now luck and have sent a email with no response
bragg2000
Still not working
hummuschips
On the iPhone go to settings -> phone -> call forwarding and see if it's turned on.  It's also worth going into "call blocking & identification" to make sure you didn't accidentally block people that you want to receive calls from.
bragg2000
How would forward calls to messages
bragg2000
Yes it says correct number for out going calls. I phone 6
hummuschips
First of all, when you make outgoing calls do they see the correct phone number on their side?  Second, which phone do you own?  I would check if you have call forwarding accidentally turned on to forward all incoming calls to voicemail.
bragg2000
About one month ago
bragg2000
Yes I did but it was working
CaNuCk07
hello! have you recently ported your number?  Can you provide some more info regarding your problem?
