I can't login into my self-serve account anymore.
Generationace
I think the problem started when I ported my new number from wind. Contacted mods but still no respose. I tried restting password but says my account is locked. Please help
daredogg
Hello @Generationace
Usually if the self-serve account gets locked, it means there was a problem with the porting of your number. Not sure why that happens, that your account gets locked, but you'll need a moderator to unlock your account. Moderators are gone for the day, but will be back at 9:30 am tomorrow (eastern time).
Refer to this post for instructions on how to contact a moderator...
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
Generationace
Tried to create a new account but it says its already active.
amodluvsu
@Generationace
I JUST PORTED MY NUMBER TOO NOT QUITE MINUTES AGO AND EVERYTHING LOOKS GREAT SO FAR.  YOU ARE WELCOME ONBOARD AND I LOOK FORWARD TO LEARNING NEW THINGS FROM MY PREDECESSORS.
THANKS
chinaweike
I just ported my number from wind and all good. I think your locked account issue can only be solved by mod. or maybe you can create a new account.
