04-24-2023 07:39 AM - last edited on 04-26-2023 10:12 AM by Dunkman
Can some help me, I brought $30 to top up my cellphone on April 9th but I didn't receive anything
04-24-2023 10:35 PM - edited 04-24-2023 10:35 PM
@TommyG12to me, this is really not something to ask PM
When you bought the voucher from any site/shop, the site /shop are the one to deliver you the voucher, PM is not the one to send yuu the voucher code
If you have received the code and cannot use it, the it is PM's responsibility. But in this case, it is the middleman failed to sendi you the code. I think the site just not taking the responsibility and passing the bucket to PM
04-24-2023 10:27 PM
Yes I am sure I brought a $30 public mobile voucher card as i usually buy it with them using cro but I didn't get a redeem code to be able to us the $30 nor an email just $30 lost
And I look at all my email they didnt send me anything about my purchase as they usually do. I ask them about this and they told me to contact the Merchant which is public mobile because the payment went through
04-24-2023 08:52 AM
You could try asking the customer support agents to verify the voucher for you.
Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
04-24-2023 07:54 AM
@TommyG12 so, you bought voucher via them ? you sure you got the PM voucher and not Telus or Koodo? Also, they should have emailed you the code, check the spam folder. If you never received the code, this is something you need to work with them and I don't think PM can help
