07-10-2021 01:57 PM - edited 01-06-2022 02:59 AM
I am not receiving incoming calls. I can't figure out how to solve this problem without a moderator.
07-10-2021 03:41 PM
Hello,
did you get a new sim card from PM?
07-10-2021 03:33 PM - edited 07-10-2021 03:34 PM
@neward69 wrote:I am not receiving incoming calls. I can't figure out how to solve this problem without a moderator.
Hello @neward69
Try a Reset of your Network Settings.
If still issues, try your SIM into another compatible Public Mobile phone, this should rule out a phone issue.
Are you an iphone that changed numbers or phones recently?
Set up your phone number On your iPhone:
07-10-2021 02:27 PM - edited 07-10-2021 02:28 PM
Did you recently port your phone number over to PM ? Try rebooting your phone. If you still need assistance then submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
07-10-2021 02:25 PM
@neward69 is outgoing calls working? try reseat the sim. Power down , take sim out for a min before before put it back
07-10-2021 02:10 PM
Could you provide some more details, like how long you have PM service, were you able to receive calls before, when you encounter this issue, does SMS send/receive works, etc.?
07-10-2021 01:59 PM
can you try it selecting the network to "3G ONLY"
for iPhone visit HERE
or HERE
for android visit HERE ,
if you still not working do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
