4 weeks ago
I have my phone and tex working, now i need to get the data part working. Help
4 weeks ago
hi @Hinbest
you have trouble turn on mobile data? or data is on but does not work?
what phone do you have? Try Reboot phone once more and then Reset Network Settings
if you have trouble turn on mobile data:
To turn on mobile data (cellular data) on your iPhone, open the Settings app, tap Cellular, and then toggle the Cellular Data switch to the on position. If you have multiple SIMs, you may need to go to Settings > Cellular >
Cellular Data firstTo enable mobile data on a Samsung phone, you can either use the Quick panel or the Settings app. To use the Quick panel, swipe down from the top of the screen and tap the mobile data icon. Alternatively, open the Settings app, go to Connections, then Data usage, and toggle the Mobile data switch to On.
4 weeks ago
@Hinbest Ensure you have dat turned in in phone settings can also verify APN settings
APN settings
