12-29-2022 05:55 PM
My new company is trying to transfer out my public mobile number, however public mobile is not honouring my request through the other phone company
12-29-2022 06:15 PM
The phone number is correct. I’m unable to access my text messages or text or phone calls. So I need to get correspondence via email or community
12-29-2022 06:12 PM
@Jamie11 wrote:I cannot access any text at present. It must be sent via email. The phone number given is valid
Hi @Jamie11
what is the reason you cannot access text?
it is a rule for all carrier to send text and get a text response YES to complete porting. It is not PM not cooperating. All carriers need it as a proof to avoid SIM fraud. They won't just accept email
if you lost your sim card and cannot receive and reply text, you have to open ticket with PM and hope they can work out something with you.
but the worst case is you have to get a new PM sim , set it up to your account and then follow the proper procedure to receive text for the porting
Please open ticket with PM CS agent and try to work out something
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-29-2022 06:08 PM
12-29-2022 05:59 PM
HI @Jamie11 you have to tell us clearly what you meant by " public mobile is not honouring my request through the other phone company "
did you just not receiving the porting text from PM? if so, there are many reasons for that. Maybe you didn't give the new company the proper information. did you give them the correct phone number? (don't laugh , many people entered it wrong).
Did you give them your account number or just IMEI? Giving IMEI might work but proved to be problematic in many cases
Tell us exactly what make you think PM is not "co-operating"
12-29-2022 05:58 PM
Did you replied to the text from PM confirming that you are porting over to another carrier with the PM SIM in your phone. There will be 90 minute window for you to reply.
Also your PM account must be Active.
Both of these are required to port over successfully or your porting request will be cancelled.
12-29-2022 05:57 PM
@Jamie11 @Are you trying to port to Koodo ?
