How to change credit card
apvm
I am planning to change my credit card, I have autopay $2 discount, if I cancel the autopay and add the new card will it affect the autopay discount?  Thanks.
7 REPLIES 7
Temporarily disabling autopay and/or removing your card and then adding a new card and re-enabling autopay will not affect your reward.  After turning autopay back on, the $2 reward gets immediately reinstated.  As long as autoapy is enabled at the time of your renewal, you will get the discount.
guitarpickr
Hi there, you'll have the option to either replace your card or cancel your card. Just replace your card and the auto pay will still be on. Cheers!
Ali03: Yes. Autopay is just an on off switch.
Ali03
Do you mean
- replace or update cc will not remove auto pay
- remove and add new cc will remove autopay and then need to enable autopay
dust2dust
The replace card option will keep autopay on.
The remove card will turn off autopay. Then add the card and turn autopay back on.
@apvm
Yes, once you cancel AutoPay…you loss the $2 credit off your bill.
Just go to Make a Payment and change the CC information and keep AutoPay on.
Yummy
If you remove autopay you will lose $2.
You do not have to remove autopay in order to update CC info.
Just follow links
