09-07-2022 06:54 PM
09-07-2022 07:57 PM
Ahhh...gotcha. Yes, the PM bean counters wouldn't like that at all.
I didn't know the bank could claw back $$...but it makes sense now.
Thanks
09-07-2022 07:54 PM
@hairbag1: If you or the bank suspect fraudulent charges have put on the card then the bank takes back the money from vendors. For here that means the customer got free service. They don't like that.
09-07-2022 07:09 PM
Sorry...been painting house today so probably paint fume poisoning...but... what is a chargeback anyhow ?
09-07-2022 07:04 PM
@hairbag1 it is trouble with a chargeback because PM is prepaid. Anyone had a chargeback will have to use voucher to top up with the help of PM support for 12 months before their account will be back to normal
@Robert1Stone If that is a charge back situation, please open ticket with PM support using method 2 above. You will need to work with them for a resolution. If the chargeback was only by mistakes, maybe PM support can work out something with you
09-07-2022 07:01 PM
@dust2dust wrote:Use the option 2 above. Only they can help you.
Others: it appears this customer is in a charge back situation.
What's the significance of a charge back ?
09-07-2022 06:58 PM
09-07-2022 06:56 PM - edited 10-20-2022 04:10 PM
@Robert1Stone do you have access to My Account now? I thought you had another post about not able to login
If you now have the access back, just go to Payments page, click Manage Payment Method and then Update Card information
But if you still have problem logging in, please open ticket with PM Support to sort out to login issue first:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
