07-01-2022 01:56 PM
HI, I just set up a friend for Public Mobile. I haven't done that for a while and I never used the friend referral code before so I had to skip it. Now my friend is all set up on Public mobile but now I want to register my code so that we both get the friend referral. It says that I can do it within 48 hours to still get it but how and where do I go to do that? Do I do it on my account or hers? Thanks for your help:)
07-01-2022 02:01 PM
@TonyE Yes, you have to have your friend, the newly joined one, to open ticket with PM support and have them to add it back manually.
Have your friend to open ticket using one of the two ways below:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-01-2022 02:01 PM
07-01-2022 02:01 PM - edited 07-01-2022 02:02 PM
@TonyE hi you need your friend to contact customer service you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
07-01-2022 02:36 PM
The only problem is that I set everything up for her as she is a refugee from Ukraine and fleeing the war. Her english is minimal so I did everything. Can I do the conversation with the CS agent as it would be al ot easier for everyone involved?
07-01-2022 02:42 PM
@TonyE good thing for PM is that the support is online
So, if you have her permission, setup a Community account for her. You can help her to open the ticket using her account and her My Account credentials.. PM likely will validate the identity by asking different questions, with her permission, you can reply on behalf using her Community account 🙂
07-01-2022 02:43 PM
@TonyE When you submit a ticket using the link already provided, request a live chat (no guarantees) but it's accommodated on a case by case basis. Good luck.
07-01-2022 02:47 PM
I sent a message to a CS agent to see if they can do that for us. Thanks for all your help:)
