09-28-2015 08:45 AM - edited 01-04-2022 02:02 PM
Hi Everyone,
I have question for reward, If i want set up 2 phone line, can i refer myself.
Just wondering.
Thank you very much.
10-02-2017 05:13 PM
Note, the referral only works in one direction, as the first account must be created and operational first.
10-02-2017 12:11 PM
@imm1304 wrote:Thats correct. I have 2 accounts with the same name.
Even the same gmail account is being used. I just added an extra word after "+" in gmail address as follows.
1st account: me@gmail.com
2nd account: me+2ndaccount@gmail.com
Gmail is designed so that anything added after the + sign is just a label and both email addresses refer to the same gmail account. There is an option to creat alias in hotmail/outlook as well. Hope this helps.
@imm1304, oh wow, that's a nice piece of info. Thanks!!
10-02-2017 12:02 PM
10-02-2017 11:58 AM
10-02-2017 11:42 AM
Hey @BigML,
Yes it works. Doesn't matter if you used the same credit card to pay for both accounts.
You just need 2 separate email addresses as the PM system only allows 1 account per email address.
10-02-2017 11:33 AM
@kaytus wrote:Hi Everyone,
Just wondering.
Hi,
Did you end up getting this "self referral" working?
Just curious.
Thanks,
09-28-2015 08:06 PM
Go for it, when activating just put in your phone number as the refering number and you will get $1 off for each month both lines are active.
09-28-2015 09:09 AM
Hi @kaytus, when you or your friend is activating a new account, there is an an option for referral reward. Just enter the phonen number of the person who referred you. I think you can refer yourself when you have two lines... make sure you choose two different email addresses for the two lines. You will get a text message letting you know about the referral on the first line. Good luck!
Welcome to public mobile and let us know how the activation went for you.
