12-07-2022 10:20 PM
I am unable to see any option to pick a new plan to upgrade my account.
I am unable to find a human to talk to and Simon is useless.
The instructions Simon gives does not work. This is a crazy difficult site to navigate.
Please tell me how to talk to a human! If humans are not an option tell me how to cancel public mobile.
12-08-2022 12:58 PM
@CGO Please avoid repeating others.
12-08-2022 12:23 PM
OK so once I port to anothe provider it will automatically cancel public mobile service? I just don't want to keep being billed. Thank you!!!
12-08-2022 06:57 AM
@YvonneT2 wrote:I am unable to see any option to pick a new plan to upgrade my account.
PM service is online only.
Since PM website has caches issue, so clear caches , cookies then using computer and private or incognito mode browser to login. For some mysteriously reasons, mobile device some times hard to login.
After login you can change any plan you like.
If you do want to cancel your account with PM, there're two choices: port your phone number to other provider or turn off auto pay then your account will be suspend, after 90 days your account will be closed .
12-08-2022 05:38 AM
12-07-2022 10:23 PM
So sorry, but Public Mobile is all online phone provider. So there's no one to call.
12-07-2022 10:23 PM
@YvonneT2 , please try accessing the self serve account using incognito mode on the browser. That should help. To change plan, go to the plan and add-on tab.
