History
Jenniferhill
I am trying to request copies of my call history for legal reasons.  I have sent the moderator 5 emails to no avail.
HELP! HELP! HELP!
7 REPLIES 7
@Jenniferhill   if you need how much you were charged last month, when don't you go to Payment history on My Account (without tax)  ?  or show the credit card statement (with tax)
and sorry, no phone number to call, you need to open ticket.  That is the only way
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Yummy
You can see on line and download up to 90 days of usage history showing data, SMS and calls made/received.
Jenniferhill
your submit a ticket is asking for information I do not have like how much i am charged last month
Jenniferhill
your robot cannot help me, I need to speak to someone, why is this not possible?
HALIMACS
@Jenniferhill
The call history is available on your self serve site under usage. You can sort and filter based on what you wish to receive for the past six months.
If you are looking for something further back, public mobile may or may not supply this.
They may only do so if they are compelled by court order to do so.
If you want to try your luck, here’s how you reach them.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
@Jenniferhill   email or ticket?  there is no email to send
I suggest you to open ticket using the proper chatbot way. Follow the exact steps and it shoudl open ticket with ticket number for tracking purpose:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
** Remember there are 2 login process.  The beginning one is the Community login
    At the end right before submit, there is a validation, you can use Community login or 4 digits PIN.  if trouble, use 4 digits pin
