Help - completed signup 20 hrs ago - still waiting for my phone to work.
WaldoWaldoWaldo
After completing the signup and installing the sim and completing the transfer request and waiting almost 24 hrs, the phone is still not connected to Public Mobile - now its emergency calls only.
8 REPLIES 8
@pca wrote:
I had to go into my phone settings under celluar data and manually delete my previous provider.  Then it fired up.
Deleting access points settings from a device is unrrelated to the inability to connect to the base cellular network.
pca
WaldoWaldoWaldo
OK - will be patient.
@WaldoWaldoWaldo   You can contact Public Mobile customer service by sending a private message using this link
An agent will reply at your private messages inbox, envelope icon top right or tap your avatar for Messages if no envelope.
WaldoWaldoWaldo
So who do I call?
The phone says Emergency calls only.  I see my phone sim says the right phone number. But the network says Emergency Calls Only.  My previous  provider already sent me email that they are closing my account there.
@WaldoWaldoWaldo wrote:
Its a physical sim.  And I have no other phones to test it in.  The original message from Publick mobile was that it should take about 5 hours.
It doesn't take 5 hours to get a network connection to Public Mobile. That part is immediate.  It's only the number porting that is fnished in most cases within a few hours. The way that your phone says emergency calls only isn't a number porting issue.
WaldoWaldoWaldo
@WaldoWaldoWaldo
esim or physical sim card?
if physical, test it in another phone
if eSIM, let us know, there are more to confirm
