06-22-2024
12:29 PM
06-22-2024
02:04 PM
computergeek541
06-22-2024 01:53 PM
Thanks eddieO. Chat agent page says no agents available every time. As for direct messages I've sent some but no idea where they go or how to see any reply (which at this point seems very unlikely). Ticket entry page is also a bust - for esim it says enter n/a but it does not accept n/a and all info must be completed to enter ticket.
06-22-2024 01:00 PM
Forgot to mention, using Esim
06-22-2024 01:00 PM
Thanks BKNS27. I tried to port my existing number from Virgin. I never got an SNS text about that from Virgin. All I got from a Public Mobile was activation failed athletics took my money. Now I can’t find any chat agent and I can’t get any tickets. And I can’t cancel my account.
06-22-2024 12:56 PM
Did you port your old number over to PM or did you pick a new number?
If you are porting over, did you reply with YES to the text from your old carrier that you are porting over to PM. There is a 90 minute window for you to reply or porting will be in limbo.
In either case contact a CS_Agent to complete the porting for you.
06-22-2024 12:53 PM
@Annoyednewuser, try openiung a ticket through the Chatbot https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
