HELP: Lost SIM card AND can't log in to account to deactivate it
HHF
Hello,
I lost my SIM card. I want to deactivate the account, but now that two-factor verification is in place, I can't do it (because I can't receive the text message to verify it's me).
My payments are automatically done monthly. I want to stop payments and close my account. How do I go about this?
Is there a way to deactivate the two-factor verification so I can log in as before?
HHF
No, I don't get an email option - that would be nice.
Instead, I get a screen where I have to enter my password, which I do. It shows a green checkmark, and then I can't do anything else.
@HHF - you can call # 1-855-478-2542 or # 1-855-4PUBLIC from another device and disable autopay. You will need your 4 digit PIN to do so.
IF you keep selecting "Resend Code" do you get an email option?
LitlLdy
@HHF wrote:
Hello,
@HHF ,
You can send a private message to a CS_Agent & explain your situation: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
- Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
@HHF  You can *611 to report it lost stolen or get support to help right away
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
