04-13-2021 06:42 PM - edited 01-06-2022 01:46 AM
Hi there
I am sooooooo fed up. I am trying to get into my account, My password, although correct was not accepted. I successfully changed my password and it is still not being accepted. I keep getting locked out after two tries, and I have been at this for two days. Please can someone give me some help on this before I just cancel and go to a new provider.
I realize there are different passwords for community and account.
04-13-2021 10:17 PM - edited 04-13-2021 10:20 PM
@Shastadaisy wrote:Hi there
Hi @Shastadaisy yes that would be really really frustrating. I recently changed my password and I had the same problem and after so many tries, I got locked out of my account.
It turned out to be my fault. I ignored the instruction on the private message the moderator had sent me...
Note that before you will connect with your new credentials you will need to clear the cache & cookies on your device.
If you had done that and still not able to log in your account, wait an hour before you try again.
If problem persists, contact again the moderator you are in contact with.
Please keep us posted
Aloha
RosieR
P.S. I love Shasta daisy
04-13-2021 09:58 PM
I’d contact a moderator before I’d give up on public completely. It definitely sounds frustrating.
04-13-2021 09:07 PM
If you're allowing your computer's autocomplete to put in these fields, try manually typing them
04-13-2021 06:59 PM
Website is finicky at times. Maybe try a different web browser, clear cache or incognito mode.
Some basic account functions also can be done by dialing 611 on your phone:
https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352
04-13-2021 06:58 PM - edited 04-13-2021 06:59 PM
@Shastadaisy , okay that would be really frustrating, especially since we need to access our Self Serve for many things.
Try these things:
Just checking...Are your service working okay?
If SIMon bot is causing you issues, you could also use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
04-13-2021 06:53 PM
Please contact the PM moderator by clicking on the SIMon Chat bubble and ask that you want to contact a moderator to reset your password.
