09-13-2025
09:38 PM
09-13-2025
11:34 PM
computergeek541
gave away my iPhone 15 and no longer have access to it
I do have a backup iPhone XR and I don't know how to activate it with a new esim (I believe it can esim or regular sim) I do have an unused physical sim sitting around but would prefer to use the esim
how can I get my number and esim into my backup phone ?
thanks!
09-15-2025 08:04 AM
Thank you for the escalation! The customer is in contact with an agent.
09-13-2025 10:56 PM
thanks ! I managed to get the sim installed after many error messages I just kept trying and it finally worked thanks a lot !
09-13-2025 10:43 PM
the "spare" PM sim has to be a new one that was never been used on any account before. If it is, then login My Account and go to Profile, update the sim card number by clicking the pencil beside SIM card number there
Just in case that still does not work and still need CS agent to help, I have escalated your ticket on behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
09-13-2025 10:40 PM
had a spare physical sim which I put into my XR but it doesn't show my old number
09-13-2025 10:30 PM
tried a message to support but no luck so far
09-13-2025 10:29 PM
yeah, doesn't work, the app kicks me to the web page on the phone and there option to submit the 6 digit code i.e. there is no "SUBMIT" button on the web page
09-13-2025 10:12 PM
@frogmeister maybe it is a payment issue
Try to load enough funds ahead using this link on a browser first
https://myaccount.publicmobile.ca/en/account/payment/funds/card
if you can load funds successfully, you can go back to the app and re-buy eSIM
if you cannot load funds, then you might want to get a voucher from SDM/LD/711/Shell and then load the vouchers first and try buying eSIM again
if none of those work, then consider changing back to physical sim for now. Get a Public Mobile sim card from
09-13-2025 10:07 PM
yeah thanks I got the code via email (obviously not be phone) and logged in ok and then went to purchase an esim card but I keep getting error messages ???
09-13-2025 09:41 PM
you can still install the PM app and buy esim on the other phone
To rebuy new eSIM for FREE, first, download the app on your new phone and login. If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install
if you cannot login because you can't receive the 2FA via email or voice message, you likely have to change back to physical sim first. But check with PM CS_agent and confirm. Private message CS Agent at:
