02-04-2024
03:49 PM
02-04-2024
06:20 PM
computergeek541
I have a new 4G subscription and my iPhone SE 2nd gen is stuck on 3G. How do I setup my iPhone to access my 4G subscription.
02-15-2024 12:47 PM
Thank you so much ! Using LTE gives me 4G speed
02-05-2024 05:25 AM
@Yamadasan Set it to LTE which is the same as 4G in this case, as @Jedi1 said.
02-05-2024 12:52 AM
Select LTE in your settings. You should get the 4G speed on this setting. My son has the same phone.
02-05-2024 12:43 AM
I tried to reboot and it still shows 3G
02-05-2024 12:42 AM
I am currently on the 4G plan and on my settings it only shows the 2 options LTE or 3G
02-04-2024 04:07 PM
@Yamadasan If you go to settings - cellular - cellular data options - voice and data, what does it say there?
02-04-2024 03:59 PM
OK. Another question would be, are you currently on the 4G plan or is it pending change on the next billing cycle?
Also, the area you're in may have weak signal to get the 4G. Which is odd but still can happen. What happens if you go outside?
02-04-2024 03:56 PM
Still stuck on 3G. Thank you for the reply
02-04-2024 03:50 PM - edited 02-04-2024 03:51 PM
Hey @Yamadasan
I too have the iPhone SE 2020. Just go into network settings and choose Public Mobile as your provider and reboot. It should show 4G. However, if you're out of 4G range and 3G is only available, it may show that.
iPhone - Settings - Network Settings - turn off automatic and choose Public Mobile - Then reboot.
