03-06-2022 03:09 PM - last edited on 03-06-2022 03:16 PM by Dunkman
My friend was told the code I gave him for rewards was no good was no good.
He joined Public Mar 5, 2021.
His number is 902-xxx-xxxx
Edit by Dunkman: removed personal information
03-15-2022 10:32 PM
@FrankFawson wrote:Hi
Thought I would give this a little time to see if it rectified itself.
Customer support told me the friend I referred had to contact Public after telling me the pin he had given the person at the Koodoos kiosk was not good.
He did contact Public but no success.
What next?
There isnt anything specifically that you can do. This was mentioned earlier in this message thread that your friend has to contact a customer support agent. This is all in your friend's hands. Please have your friend follow the instructions provided earlier.
03-15-2022 07:21 PM
Hi
What next?
Thanks for trying
Frank
03-06-2022 03:28 PM
It shouldn't make a difference as he can still give your referral code.
03-06-2022 03:28 PM
HI @FrankFawson sometimes code is no good because it was copied wrong. Friend referrals are good to be used in store or online activation. if he was told the code wasn't correct and he already activated, just have your friend open ticket with PM Support as advised in my earlier post
03-06-2022 03:27 PM
It usually takes about 72 hours to see that he got the $10 reward. If he doesn't see it, I would recommend your friend to talk to the livechat box.
03-06-2022 03:24 PM
He joined Public in a mall at a Koodoos kiosk. Will that make a difference in why he was told the code was no good
03-06-2022 03:14 PM - edited 03-06-2022 03:15 PM
Hi @FrankFawson What was no good?
did he joined Mar 5 2021 or 2022?
It takes 72 hours for the Referral $10 to show up on the new account. If it has just joined, please ask to wait 72 hours
If still not seen the $10 credit after 72 hours, Have your friend to open ticket with PM Support. Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
03-06-2022 03:14 PM
Your friend needs to contact customer service agent to give the right code. Maybe copy and paste your code since sometimes number 0 zero and lettter O can be mixed up. Customer service agent should be able to help.
P.S. I will remove his personal information from this public website.
