11-18-2016 05:41 PM - edited 01-05-2022 12:36 AM
11-18-2016 09:20 PM
Hi @anele26;
This will require a moderator to fix, and unfortunately they are way behind right now due to this promo, so won't likely get to you for several days. The good news is that PM has indicated that they will honour the promo even after the 20th for people in your situation, see http://productioncommunity.publicmobile.ca/t5/Announcements/Doing-wireless-different-has-its-ups-and...
What you should do at this point is send a private message to one of the mods, include the info as per this post http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/All-you-need-to-know-about-our-Communit...
You will need to be patient, but they will get to you.
11-19-2016 06:26 AM
11-19-2016 07:44 AM
You're welcome @anele26!
I don't think there is any way to pull back pms, think you should just resend with the additional info.
11-19-2016 08:34 AM
