Exceeding Your Minutes
c70nut
Can someone tell me what happens if you go over your plan limits, either minutes or number of texts?  Are you charged extra or is it just capped at the limit?   Tanks!
7 REPLIES 7
Master2000
@taullboi
You can buy "500 min Canada-Wide Long Distance" @ $5. You will use those minutes when your plan minutes are all used and they never expire (Any unused minutes will roll over to your next cycle.).
GR
@taullboi  there are not!  Autopay is only for the renewal.
taullboi
I would like to confirm that there are no overuse charges even if you are on autopay.
@CellAid wrote:
That's the beauty of pay-as-you-go, no overage charges here 😉
CellAid
ShawnC13
Your service will stop working.  PM is fully prepaid if you haven't paid for it you won't have it or get charged extra for it.  For talk you can purchase a Long distance addon and use those minutes.  They do not expire and are on your account until fully consumed.  Unfortunately there is no addon for texting.
surreyboz
With Public Mobile,  What is not included in your plan or add on stops working when used up. There are no overages or pay per use charges what so ever. Period
The feature just stops. No extra charges here.
Get talk add-ons if you need talking.
