Every self-service option says 404 or maintenance
JennyLM
Every option I choose from the self-serve portal main page says the page is not found or is under maintenance.  I cannot do anything.  I cannot add add-ons.  I have no data and need to add data.
When will it be working again!
will13am
Everything is working for me.
@JennyLM
logoff first.   wait 2 mins, try again with another browser,  Edge/Firefox/Chrome..
dabr
@JennyLM    If you know your 4 digit PIN and have a CC registered on account, you should be able to purchase add-on data by dialing 611 and following prompts.
Yummy
Nope. It works as expected.
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
