10-31-2022 03:54 PM
I need to change the email on one of my accounts. How does one get this done?
Service
10-31-2022 03:56 PM
@MaR2307 If for the self serve account then submit a ticket via chatbot here: https://www.publicmobile.ca/en/on/get-help
If for your Community account, then click your avatar and select Profile and you can update your email by yourself.
10-31-2022 03:56 PM
Go to top of this page click Get Help / Chat with Simon to start process of CSA assistance.
Watch the little envelope icon on top right side of page will be highlighted when they respond.
10-31-2022 03:55 PM - edited 10-31-2022 03:56 PM
You need to get a Customer service person to do that for you. You can't do that yourself.
Use the chatbot Simon or send a private message to CS_Agent
10-31-2022 03:55 PM
HI @MaR2307
you will have to open ticket with CS support for email address change:
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
