01-17-2023 09:18 PM
Hello,
I activated a new public mobile sim card and entered in my details. However, when I try to login, it doesn't work but I thought the account was supposed to be created already when you activate a new sim online since they asked for all the details including email ID and password? Please help me! Thanks!
01-17-2023 10:08 PM
@Dipti99 initial response from agents seem to take the longest but once you get a reply any back and forth communication from that point is fairly quick and painless . Hope you get things sorted out and resolved quickly
01-17-2023 09:47 PM
@softech yes PM service is working but unable to login saying email and/or password is incorrect. I also never got any email from PM regarding my service activation. When I try to reset my password (thinking I got the password wrong which I clearly believe I didn't), I enter in my e-mail ID, but don't receive any password reset link on that e-mail. I have created a ticket with the CS agent so hoping for their reply soon. Thanks a lot for your help though and thanks to everyone else on here too for their help and support in providing me with various different troubleshooting approaches and solutions.
01-17-2023 09:40 PM
@Dipti99 @You may need to reach out to support to regain access then
01-17-2023 09:38 PM
@Dipti99 your PM service is working? if it is working, the account is there, just a login issue
Open ticket with PM Support and they will double check the login
01-17-2023 09:38 PM
@Dipti99 wrote:Hi @Handy1 It doesn't work unfortunately...I just activated it so should I wait? It doesn't even allow me to reset my password saying my email ID doesn't exist which makes no sense when I clearly activated the sim online and it works on my phone.
@Dipti99 , no it doesn't really make sense does it. 😕
For My Account log in issues, you can submit a ticket here to: Create, forgot or change My Account email or password link
01-17-2023 09:34 PM
01-17-2023 09:30 PM
@Dipti99 , did you receive a welcome email? That is usually a good sign that the activation worked. It also validates the email address used in the activation.
01-17-2023 09:23 PM
you tried using Incognito mode to login ?
if still fails, open a ticket with PM Support and they can sort it out for you
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
01-17-2023 09:20 PM - edited 01-17-2023 09:22 PM
@Dipti99 Try again incognito mode private mode or a different device like a lap top there are cache issues
and yes your correct you do creat an account when you activate the sim .. you usually have to do a two step verification after signing in the first time after activation also
