During sign up Sim was accepted and when I tried to activate then they said the aim was already in u
PeterHild
2 REPLIES 2
@PeterHild
Are you saying that the account already exist?
hi @PeterHild
did you start the activation using the browser, and now trying to complete it using the app.  If that was what you are doing, you need to use the same email address to login
but if you are confused, support agent can help.  You can submit  ticket by direct message:
