During a call I get annoying sounds like click or hang up
CountyDownIeUk
So was on a call and I hear interference. Like clicking and a hangup. I then find that I had an voicemail.
So when you are on a call....does this happen to you too??
10 REPLIES 10
@esjliv wrote:
@CountyDownIeUk , no can't say that happened to me.
So why didn't it come in that you were getting another call? Do you have it set to go to voicemail when you are on a call?
Part of the problem I was clueless it was there. And have no use for it, so will disable.
It is strange, almost like the 2nd caller nearly interrupted your current call.
Exactly, I thought who I was talking to, hung up on me.
Was your device connected to any bluetooth devices?
No.
Thanks everyone.
I found the codes to enable and disable Call Waiting on the ZTE box.  Will set it and test it soon. 😀
i had no idea of this wonderful feature.  But won’t use. 🥴
@esjliv
Thanks. I had no idea. I turned call waiting and call forward off on my and my wife’s iPhones.
I DO use call forward on our land line but prefer to turn off and on by manually keying the codes.
My my wife and I prefer to not have call waiting as we consider it rude to put some one on hold.
@CountyDownIeUk wrote:
1.  I have no idea that I could have the option to answer another call while on a call or the option to  direct it to voicemail.
ah, okay @CountyDownIeUk .
As for #1 above, my phone as these settings, so that is what my thought went to.
I do not have any call forwarding set up currently on my device.
Now, if I am on a call, and another call comes in, I can choose to reject/decline it and it will go to voicemail.
Community_QA
@CountyDownIeUk   we have no short of "Timely" replies here
2. I purposely did not mention that our home land line is actually a PM $15 plan with the SIM in a ZTE box. Reason for not mentioning was 2 fold.
A. I did not want any “Timerly” like  pros telling me what my issue is.
AND
B. Curious to only know what happens when using a cell phone. Then I would take it from there. I guess we don’t use our cell phones enough to be on a call while a second call occurs. 😀
Community_QA
Do we need to answer every single post even you don't have an answer?
if you don't know, can't you just leave it alone?
Like I have no answer to @CountyDownIeUk , but I won't say "maybe you hear wrong, you hear again"
@Timer wrote:
@CountyDownIeUk
maybe some app is still works, you hear.
Maybe not and just another stab in the dark.
Timer
@CountyDownIeUk
