06-01-2023 11:45 PM
I have a lot of dropped calls and often poor signal. In different locations. So much so that I'm considering moving to a different cell phone provider. Can this be resolved? Any suggestions?
06-21-2023 07:32 PM
how do i see how much data I am using per month with public mobile? I clicked on the usage history but it is just showing outgoing/incoming calls. Still having a lot of dropped calls and poor signal despite resetting the network settings and powering down my phone.
06-05-2023 03:48 PM
@bubie no wifi calling
you have a chance to test your sim in another phone?
to reset all networks
Settings app > scroll to and select General > scroll to and select Transfer or Reset iPhone > select Reset >select Reset Network Settings > select Reset Network Settings again to confirm.
06-05-2023 03:43 PM
@bubie No sorry PM dosent support wifi calling yet .. Koodo does thou if this is important to you
06-05-2023 03:42 PM
thank you. is there a way to turn on wifi calling?
06-05-2023 03:39 PM
@bubiein phone settings >cellular >cellular data network and reset
06-05-2023 03:37 PM
How do I test network settings? What do you mean by this?
06-05-2023 03:36 PM
How do I reset all networks? I have an iPhone SE 2. I have LTE.
06-05-2023 03:36 PM
I have LTE. I have an iPhone SE 2. What do you suggest next? It has been dropping calls and poor signal for years.
06-02-2023 12:18 AM
Is this a new problem or has it always been an issue? What do you have your network set at, and do you know if you have. VoLTE yet? It's possible you're falling back to a 3g network which may not be as stable as it once was. To test if you have VoLTE make sure your network selection is set to automatic, turn wifi off, and watch what network you're connected to when you make a phone call. If you stay in LTE/4G/5G when you're on a phone call, then you have VoLTE. If you drop to 3G, you may not. What phone do you have?
06-01-2023 11:47 PM
What model and brand of phone do you have?
If you have a very recent phone from one or two years ago, you can try to enable VoLTE and see if it wworks better
if older phone, try to change the Preferred network type to 3G only (or WCDMA only) and see if it helps
Last, you can try to Reset all networks and it could help too
06-01-2023 11:46 PM
@bubie Is it possible to try simcard in another phone to see if it works ? Also try testing network settings
