Don't get messages from the Ukraine
krisyarmak123
I can text to Ukraine, but my friend cannot reply to me (he has add-on for international calls/texts). Do you know why is that?
10 REPLIES 10
krisyarmak123
Thanks. He's going to talk with his carrier
@krisyarmak123 wrote:
Yes, he has iPhone. I allow everyone to call/text me, not only my contacts
Ask your friend to look a failed message, press and hold it until he sees an option to send as SMS, and send again.
 I am totally confused by your response that you can see a message received in your self serve account that does not appear on your phone.
krisyarmak123
It did come in
Thanks
@krisyarmak123 if that's the case then it's your phone. Is it an iPhone?  Do you allow to receive texts from people that are in your contacts only?
krisyarmak123
Thanks for your help
krisyarmak123
I get messages from everyone across Canada. Well if he chats in Ukraine, he doesn't have problems. That's only with me
krisyarmak123
It did come in
Thanks
geopublic
@krisyarmak123  Check the usage history logs to see if the text came in. If yes, then must be a setting with your phone. If the entry doesn't show up it means that there is a problem with your friend's phone or his provider.
cavemantoronto
You get messages from others?  Make sure you aren't blocking him by accident. Check archived messages.
It could be his side, could be yours.  Does he have trouble texting other people?
Dunkman
@krisyarmak123
Hard to say for sure.
Public mobile has international text so you should be able to receive Ukraine text.  You can text to him.  Probably an issue with his service/mobile carrier in Ukraine.
