06-07-2025
04:17 PM
06-08-2025
12:04 AM
computergeek541
I need to travel back and forth between the United States and Canada for work. I need to confirm whether the 60G traffic in my current package will be cut off after it is used up, or will I be allowed to continue using the Internet in a very slow form?
I am a bit troubled because I don't see any items like "unlimited as reduce speed" in the plan.
06-07-2025 06:35 PM
@Kolotia wrote:Oh Public Mobile can't change plans by what I pick? Thank you very much for your reminder. This is very helpful to me.
The plans advertised on the Public Mobile Shop page aren't the same as the plans you can get when you are already a customer. You can only choose from the plans shown offered to you after logging in.
06-07-2025 05:28 PM
06-07-2025 05:19 PM
@Kolotia wrote:Actually my job doesn't help me pay the bills, but the 55/MO 100G plan looks pretty good. I'll try it this month to see how my data usage goes and make a decision next month.
Actually and honestly, it would be better to grab the plan you want THEN if you feel you need more data, you can certainly upgrade at renewal. Public Mobile doesn't allow for downgrading so if you find out you don't come close to 100GB of data, you may be stuck at that price point. Thought I'd share.
06-07-2025 05:16 PM
06-07-2025 04:28 PM
@Kolotia wrote:I need to travel back and forth between the United States and Canada for work. I need to confirm whether the 60G traffic in my current package will be cut off after it is used up, or will I be allowed to continue using the Internet in a very slow form?
As mentioned, there is no unlimited data after 60GB of data. You mentioned that it's for work? Does this mean "work" is paying for this or reimbursing you? If so, you may want to grab this plan instead.
06-07-2025 04:24 PM
Will be hard cutoff. All roaming plans do not have unlimited slow Internet
06-07-2025 04:20 PM
there's no mention of slow speed data after using regular plan data so assume it just stops after used up until next regular plan renewal.
