Does it change my plan?
Iamtian
I got below message. Does it change my plan to current $18 plan (see below) or just increase the price with no other change to my plan.
Hi @Iamtian  I doubt the $18 plan will change in price any time soon. I think the price will stay for a year  or two.  PM usually just increase the price of the lowest priced plan and all other plan prices stay the same
After this increase, the lowest priced plan in danger would be the $13 plan.
we are just customers, I can only say likel not
Iamtian
Will the current $18 plan also increase in price?
HI @Iamtian
to get the $18 - 1GB plan, you need to actually click on Change on Renewal to schedule the plan change
slusagm
if you do nothing, you will keep your current plan with just 250Mb or 500Mb and pay $3 more
So, you need to click Change on Renewal button for the new $18 plan to take advantage of the better deal.
umnikke8
Just increase price. You can change to the other plan if you want.
